leninsankaralingam Posted March 15, 2011 Share Posted March 15, 2011 Hi, my relatives, I am doing a small walkthrough project of 2000 frames, rendered in max.After I got all the frames in tga format, I started to import the folder in adobe premiere pro. But my animation is moving very very slow after the export. Can please any one assit me in this problem and explain the procedure of editing the frames. Thanking you! s.lenin Link to comment Share on other sites More sharing options...
Stephen Thomas Posted March 15, 2011 Share Posted March 15, 2011 You won't be able to view it in real time unless you create a RAM preview I think. Link to comment Share on other sites More sharing options...
notamondayfan Posted March 15, 2011 Share Posted March 15, 2011 have you exported your frames from premier? if so, is it running slow because of the compression (maybe lack of compression) and your PC cant handle it? Try different formats, and try running it from your desktop. If its slow in premier, as Stephen said, you need to look at the RAM previewer. Also something else to check is at what frame rate you are importing / exporting your footage. If you are importing at 10 frames per second, the animation will be slow, so check your import settings, I dont know what's standard in Dubai. Link to comment Share on other sites More sharing options...
