laurentz Posted March 16, 2011 Share Posted March 16, 2011 Hello, Fryrender try for a few days and I have little problems with the grouping of lights. Let me explain, my scene is done with 3ds Max 2010 x64 is a building with 6 floors, offices, corridors, lockers with their own lighting in each office there is a source of light. corridors have 6 blocks light from floor bins have 6 neon block of 20 lockers. in total over 6 floors so I have many light sources and management layers with the sign "subject properties" becomes an ordeal! I have assembled my sources in 3ds max but it changes nothing. I can not understand or I make a mistake. thank you very much "to enlighten" my lantern as they say in France PS: sorry for my approximate English, I use google translation! @ + Lawrence. Link to comment Share on other sites More sharing options...
Fran Posted March 16, 2011 Share Posted March 16, 2011 Hi Laurent, I think we need a picture to look at. Is this an exterior render? Link to comment Share on other sites More sharing options...
laurentz Posted March 16, 2011 Author Share Posted March 16, 2011 Hi Frances, yes it is made out here is a picture that illustrates this. thank you very much for your help Frances. Link to comment Share on other sites More sharing options...
RayOfLight Posted March 17, 2011 Share Posted March 17, 2011 did you add the Fryrender Object modifier to every group of light-objects (geometry) with a different Fader# for each group (maximum of 16, including daylight)? Link to comment Share on other sites More sharing options...
laurentz Posted March 17, 2011 Author Share Posted March 17, 2011 Hello, I do not actually know this option, I'm gonna change, I think that's my problem. thank you very much, it's cool;) Link to comment Share on other sites More sharing options...
laurentz Posted March 19, 2011 Author Share Posted March 19, 2011 hello, I come back and still have the same problem. I assigned the modifier "Fryrender object" to my editable poly then I grouped the editable poly. I assembled the editable poly. I assigned the modifier "Fryrender object" groups. 1 group with Fader # 1 1 group with Fader # 2 my problem is that in Fryrender tab "OBJ" poly are not grouped I have to redo the same operation, so what is the interest to do so in 3ds max? there is something that I do not understand, but what? Link to comment Share on other sites More sharing options...
RayOfLight Posted March 20, 2011 Share Posted March 20, 2011 try this: - make groups of your editable poly object that are light - make several groups - assign Fryrender Object modifier to each group (1 to each group) with different fader# - in Fryrender start rendering - go to tab LightMixer - play around with the intensity sliders and color boxes of the used fader#. - You can also do this after rendering, or after loading a .dsi file. Link to comment Share on other sites More sharing options...
laurentz Posted March 20, 2011 Author Share Posted March 20, 2011 hello, yes it is the procedure I use though. I vai resume scene since the beginning there must be a problem inside. thank you very much. Link to comment Share on other sites More sharing options...
laurentz Posted March 21, 2011 Author Share Posted March 21, 2011 hello, ok i got it, it's pretty simple after all. thank you. Link to comment Share on other sites More sharing options...
Fran Posted March 21, 2011 Share Posted March 21, 2011 Hi Laurent, Can you explain what the exact problem was and your solution? Link to comment Share on other sites More sharing options...
laurentz Posted March 21, 2011 Author Share Posted March 21, 2011 Yes my problem was that the tab OBJ Fryrender all my lights appeared as a single object in 3dsmax while they were well grouped and assigned to a fader with the modifier "Fryrender object". I corrected the problem by taking all my editable poly (lights) one by one and found errors in my assignment groups of lights. Link to comment Share on other sites More sharing options...
laurentz Posted March 21, 2011 Author Share Posted March 21, 2011 I explained that it was just a small test to learn to use and test the capabilities of Fryrender and maybe adopt it (if I metrized) to make the 3D architectural exterior and interior. I think the main advantage of Fryrender is the exploitation of multi GPU. was a result of very good quality in a short time and with just two NVIDIA SLI graphics catre GTX470 + GTX480 coupled to a processor i7 950 and 12GB of DDR3. must now be in good working cooperative network to operate more machines and this will be perfect. Link to comment Share on other sites More sharing options...
RayOfLight Posted March 21, 2011 Share Posted March 21, 2011 I don't want to spoil it, but Fryrender only uses the CPU for rendering. Arion is the other product from RandomControl, that is the one using both CPU and GPU, and harnesses a tremendous amount of raytracing power! Link to comment Share on other sites More sharing options...
laurentz Posted March 21, 2011 Author Share Posted March 21, 2011 Yes indeed ARION not Fryrender I agree. it only needs the "blinder" to ARION to make it perfect. Link to comment Share on other sites More sharing options...
