animated sea / water surface in max
popoff
Hi guys,
do you know how to create realistic animated water/sea surface inside max without using plug-ins?
I saw amazing results on youtube, but there was no explanation "how to".
Link to tutorial would also help.
:confused:
The Understanding the Elements books are a great resource for this kind of thing.
For water try two animated noise modifiers on a plane, rotate the gizmos so they ar at 90 degrees to each other, play around with the z size and animate the phase. Then make a vray material with a cellular map set to fractal in the bump channel or you can use smoke and animate the phase. Reflection is key to realistic water a good sky with clouds adds depth and areas of contrast.
There are some decent ocean/water shaders on the Vray Materials website that might save a bit of time.
alrawli : thanks for your reply ,
your idea to animate already created water mats from vraymaterials.de is pretty useful.
I made 2 wave modifiers + 1 noise.
Smoke must be placed also in bump slot - right ?
I`ll post my sea scene here when work is done.
