architune Posted March 17, 2011 Share Posted March 17, 2011 Hi, This is my uni project. The building's concrete flat slab will be extended from the brick partition wall. 1) Concrete will gain heat from sun in day time and release them in the interior in night time. Like passive heating. The question is is there any minimum thickness required for this strategy? or any thickness flat slabe can do this passive heating? 2) It will work in winter. But what about in summer? will it create overheating? Thank you. Link to comment Share on other sites More sharing options...
tcupp Posted March 18, 2011 Share Posted March 18, 2011 I am by no means a pro at such a topic but I would say that it largely dependent on the climate. It would be a bad idea in a very cold climate as cold transfer in the winter into the interior would cause cold floors at the perimeter. I even know that there are systems that are made just for this purpose, to provide a thermal break between exterior concrete decks monolithically poured with interior conc floors. Now if you are in a more temperate climate then I would say that you would want some form of heat/cold transfer deeper to the interior than the concrete would provide. Ie- use the slab as the collector to transfer the heat cold to something like water that would be pumped into the interior. Just my 2 cents. Link to comment Share on other sites More sharing options...
Brodie Geers Posted March 18, 2011 Share Posted March 18, 2011 Google "thermal mass." As i recall from school any amount of concrete, stone, or brick will do what you're talking about to some extent but if there isn't enough "mass" the effects would be negligible so ideally you'd want as much as you can. -brodie Link to comment Share on other sites More sharing options...
