gdamaso88 Posted March 22, 2011 Share Posted March 22, 2011 I've been having this issue with my max interface. We've tried reinstalling the whole program and switching the driver from directx 9 to 10, but none of this is working. See attached image Any ideas? Link to comment Share on other sites More sharing options...
asarria Posted March 22, 2011 Share Posted March 22, 2011 Load up the CUI again from the CUSTOMIZE > LOAD CUSTOM UI SCHEME and reload your interface . . . it works!! Link to comment Share on other sites More sharing options...
gdamaso88 Posted March 22, 2011 Author Share Posted March 22, 2011 reloading the cui did not work. what I did find is that when I sign in as a different user this does not occur...any more suggestions? Thanks Link to comment Share on other sites More sharing options...
luthias42 Posted March 22, 2011 Share Posted March 22, 2011 try hitting CNTL X Link to comment Share on other sites More sharing options...
gdamaso88 Posted March 22, 2011 Author Share Posted March 22, 2011 cntrl x works temporarily but it goes back to a blank Link to comment Share on other sites More sharing options...
Sketchrender Posted March 22, 2011 Share Posted March 22, 2011 Sounds like a memory problem. Have you restarted and only used max and see what happens. Link to comment Share on other sites More sharing options...
David Arbogast Posted March 23, 2011 Share Posted March 23, 2011 I've had an issue with disappearing icons in Max. And, like you I tried re-installing the program with no success. So, I posted my trouble on Autodesk's 3ds Max user forum. Turns out my Max user interface got corrupted and that Max stores the UI configuration in a subfolder of your Windows user folder. Reinstalling Max won't overwrite the corrupted UI, since it isn't stored in Max's installation folder under "Program Files". To delete the corrupted UI: 1. Navigate to the “c:\users\USER\AppData\Local\Autodesk\3dsMax” folder and delete the folder for your version of the application (in my case 3dsMaxDesign 2011 - 64 bit). 2. Restart 3ds Max 3. 3ds Max will automatically rebuild the deleted files and your UI will be restored. 4. Reload all your personal keyboard/menu/quad/etc. preferences. Now a word as to why my user interface got corrupted (and caused me to lose icons): When upgrading to a new version of 3ds Max it is very tempting to try to re-use old UI preference files...but doing so causes major UI issues like this. So, the lesson learned for me, is to not try to migrate UI files to an upgraded version of 3ds Max. I don't know if any of this helps, but I had a similar situation of lost icons and wanted to share what worked for me. Link to comment Share on other sites More sharing options...
gdamaso88 Posted March 25, 2011 Author Share Posted March 25, 2011 this didn't work for me... I'm going to try reinstalling my windows user profile...I'll let you know how it goes. thanks for your feedback Link to comment Share on other sites More sharing options...
David Arbogast Posted March 25, 2011 Share Posted March 25, 2011 (edited) I'm going to try another super-basic suggestion on the level of a "is it plugged in?": Have you tried right-clicking in the empty ribbon space to confirm that you don't have your "Command Panel" and "Main Toolbar" checked? Edited March 25, 2011 by David Arbogast Link to comment Share on other sites More sharing options...
Nic H Posted March 25, 2011 Share Posted March 25, 2011 they could be in teh recycle bin Link to comment Share on other sites More sharing options...
gdamaso88 Posted March 28, 2011 Author Share Posted March 28, 2011 deleting my windows user profile and creating new one worked Link to comment Share on other sites More sharing options...
