Jason Matthews Posted March 23, 2011 Share Posted March 23, 2011 I am putting together a low res animation for a project for the client, showing everything that we will be doing in the final video. Because this is a low resolution animation we rendered everything as jpegs with no separate channels. Is there a way to add specular bloom in Premiere using raw jpeg footage or do I need the specular channel to do this? Thanks Link to comment Share on other sites More sharing options...
Fooch Posted March 24, 2011 Share Posted March 24, 2011 (edited) Use ae for that shot. Put an adjustment layer and glow on it. Mask and play w feather to control it. Plus if needed, make a black solid. Change that to a colour dodge blend mode. This will knock out the black Put a lens flare on the black solid. Tweak and tune it down If budget allows use optical flares which is a separate plugin. Or if you really really have to do it in premiere , make a lens flare in photoshop. Make the edges are not harsh. Bring it in and change the blend mode to color dodge. Key frame animate it. Might not be nice though. I am putting together a low res animation for a project for the client, showing everything that we will be doing in the final video. Because this is a low resolution animation we rendered everything as jpegs with no separate channels. Is there a way to add specular bloom in Premiere using raw jpeg footage or do I need the specular channel to do this? Thanks Edited March 24, 2011 by fooch Link to comment Share on other sites More sharing options...
