Workstation buying advice thread for April
Well, the Sandy Bridge motherboard market is back to functional levels and it's time for a refresh of this thread and of the workstation recommendations. The recommendations are here: http://www.3datstech.com/2011/03/april-workstations.html
Please ask any and all questions about computer hardware buying advice on this thread. Don't be shy now.
This month's update comes to you from the 3rd floor of the library at my school, where I've kicked out all the undergrads and finally got some peace and quiet.
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
  • 3 weeks later...
Michael, I'm going to give that assertion a definite no. This Quadro is not in nearly the same class in terms of outright processing power and the 580 would overpower it, through brute force alone if need be, in nearly anything you could think of. Read carefully: if you look at what they're referencing to get that figure, it's one benchmark (SpecViewPerf 2011's Pro Engineer test) that's undoubtedly depending on some Quadro-only feature (which is why it says "up to" 5x).
The Quadro 400 is a GT216 core with 48 threads and 512MB - it's a Quadro'ed version of a Geforce 220, which was a low end model from 2009. The Quadro 580 could reasonably be called the current fastest GPU. I can't even give you a comparison on just GPU speed because I can't find anywhere where a 220 and a 580 are included in the same chart, but the 580's GPU would have to be easily 10-20x as powerful as the Quadro 400.
Andrew, I built a machine a few years ago to act as a renderslave when using DR, but I would like to upgrade it to give my render times a significant boost. It doubles as an extra PC when my main workstation is tied up, but pretty infrequently. If possible, it would be nice to be able to turn render duties over to this machine, if I am overwhelmed with work, as well as being simply used during DR duties.
This machine has:
8GB Ram
Intel Core 2 Quad Q6600 @ 2.4Ghz
Asus P5N32-E SLI MB
Nvidia Quadro 1700
Windows 7 Ultimate 64
Its Cinebench CPU score is only 2.70 pts and Open GL is 8.90 fps. (my main workstation scores 4.49 and 27.09 respectively)
Is it possible to get significant gains with just a swap of CPU and, if necessary, MB? If so, with what? and If not, what else is needed?
Thanks so much for you advice. Dan
This machine has:
8GB Ram
Asus P5N32-E SLI MB
Nvidia Quadro 1700
I'll be watching the answer to this. I have 7 machines of the same spec!
What those guys said. i7-2600 is the best spot on the price/performance curve for most of this stuff right now and probably the entire computer except MB, RAM and CPU can be kept. Don't sweat the Quadro 1700 especially if it's a backup computer, it will be fine, and don't worry about the Cinebench OpenGL scores, they're not really that useful for non-Cinema4D users. For example, in C4D's full shaded mode the last couple generations of ATI hardware is so fast that my Radeon 5750 and i5-760 box was faster in that test than any nVidia box on the list at cbscores.com.
If you want the old system, plus the new one, build from scratch. If you only want the new one, pull the old motherboard, CPU and RAM and replace with new parts, and save some money. The new one should render about 3x as fast as the old one so maybe keeping the old one isn't a priority. The rest of the system isn't really going to have an effect on render speed so keeping the hard drive and video card etc. is fine. Just make sure the MB and case match (e.g., if you're replacing an ATX motherboard, replace it with another ATX board). Consider an i7-2600K instead of a regular 2600. It's $15 more but if you ever decide to overclock you want the K.
is this memory (sold at my local store):
Corsair
XMS3 4GB DDR3-1333 (PC-10666) CL9 Dual Channel Desktop Memory Kit
mfg part# TW3X4G1333C9A (Two 2GB Memory Modules)
The same memory as this (as listed in your buying advice):
CORSAIR XMS3 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model CMX8GX3M4A1333C9
It looks like I may have to just buy 2 of them.
I think it is, though if you can get a similar deal on... well, I don't remember the model number, but same product line, same speed only it's 2x4GB for a total of 8GB, leaving 2 slots free, that would be better. Recently the prices have gone waaaay down on 4GB DIMMS so they make sense now.
OK...got everything today and started the install. I ran into a bit of a problem though. The MB does not have a connection for my DVD/CD drive. The drive I have has some kind of 40 pin connectors. Not sure what I should do because I wont be able to load the chipset.
Do I have to now go out and buy a compatible cd/dvd drive?
