max.m Posted March 31, 2011 Share Posted March 31, 2011 i try to get a multimatte render element from objects with a blend material on them, by checking the override material effects id checkbox in the options of material. this works with every material so far, but seems not to with the blend material. i have effect id numbers and checkboxes cklicked in the base material and the coat material. also triesd it without cout, base, etc. would be nice if someone knows a solution for this Link to comment Share on other sites More sharing options...
BrianKitts Posted March 31, 2011 Share Posted March 31, 2011 are you using vray? if so.....I think you have to use the vrayblendmtl to get it to work Link to comment Share on other sites More sharing options...
max.m Posted April 1, 2011 Author Share Posted April 1, 2011 yes i am using vray(sorry that i forgot to mention that) and i am also using the vraybland material. Link to comment Share on other sites More sharing options...
