How can I make a VrayLight Material reflect?
danb4026
due to the nature of reflections and lights it's always going to be difficult to do what you want. I have some success using a blend mat with one mat being a vraylitmat and one vraymat you will have to mix them a good bit, however in order to keep you object truly lit your probably going to have extremely subtle reflections at best. I not sure if anyone else has a better idea, but that's the best one I can think of at the moment.
Good luck
I've always managed to get decent results using the Vray Blend Material. Just make sure that your coat material has black in the diffuse slot. Obviously areas that are very bright in your light material won't show up much reflections. Here's a quick test with a checker map in the light material.
another thought you could try is to use 2 objects, one with a reflective but transparent material in front and then your light box behind. just make sure that the first object is 1. a single plan and 2. that it's close enough to the box to not show any thickness and yet far enough to not give you the co-planar issues.
