cbcarch Posted April 7, 2011 Share Posted April 7, 2011 How to export to OBJ from 3dsMax with FBX materials from Revit and retain materials/maps? Workflow: Generate model in Revit 2011; export to FBX; FBX into 3dsMax Design 2011; export to OBJ. Need maps intact on OBJ model. Anyone know of a script or plug-in for Max that can do this? any help appreciated Link to comment Share on other sites More sharing options...
Thablanch Posted April 13, 2011 Share Posted April 13, 2011 Autodesk FBX converter http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10775855 Will allow you to convert the model from FBX to OBJ.. Link to comment Share on other sites More sharing options...
cbcarch Posted April 13, 2011 Author Share Posted April 13, 2011 Thanks for the reply. We have tried the Autodesk Converter, but the maps/materials to not transfer to the OBJ model. It has to do with Mental Ray Protein 2 and the new Autodesk Materials not working with the converter, or via export from Max. Link to comment Share on other sites More sharing options...
creasia Posted April 13, 2011 Share Posted April 13, 2011 This works well. Give it a try. Go to the Maxscript menu, select run script and run the downloaded file. Revit materials are converted into Mental Ray Arch+Design materials in import, so the "Material Converter v0.98b" script found at http://www.scriptspot.com/3ds-max/sc...tags/converter can convert all (or the majority) of your materials to scanline, which exports out of max into an obj format. Happy file conversions! Link to comment Share on other sites More sharing options...
