cmrhm Posted April 10, 2011 Share Posted April 10, 2011 I am trying to render a simple box with wire frame rendering technique by using vray edge material. But what I got is all the edge be rendered. How I can get rid of those edges inside a face? [ATTACH=CONFIG]42277[/ATTACH] Link to comment Share on other sites More sharing options...
Flint Posted April 10, 2011 Share Posted April 10, 2011 Have you got the 'hidden edges' box ticked in the vray material. If so un-check it. Link to comment Share on other sites More sharing options...
cmrhm Posted April 11, 2011 Author Share Posted April 11, 2011 I did. Must be something else. Link to comment Share on other sites More sharing options...
Alyosha Posted April 19, 2011 Share Posted April 19, 2011 Are you sure your box is not made of triangles? Also if it's a max object, convert it to editable poly first and see what happens. Link to comment Share on other sites More sharing options...
beestee Posted April 19, 2011 Share Posted April 19, 2011 Any particular reason you need to use VrayEdgesTex rather than vray toon? There's also the Ink n Paint material that works alright with VRay if you aren't using a physical cam or photographic exposure, just be sure to put a VRayMtlWrapper on it and disable the 'Generate GI'. Link to comment Share on other sites More sharing options...
