Convinving Gabion Walls?
Dave Buckley
cheers, steph, I think a map will suffice, the wall isn't a focal point and will not be that close to the camera, I'm just struggling to make the maps/material look convincing.
I have the stone map, and have simply created a grid over it and essentially rippled the grid to give the wire look. Looks ok in Photoshop but the render looks poor, so it's possibly the way I have the material setup.
Gonna have a play with vray blend and masks me thinks
I was just reading through the thread and as going to suggest the same thing (two boxes - one rocks, one wire) - I've used this technique before and it worked out great.
If you UVW map all the rocks in a larger set you'll help to remove repetition too.
