R.Stewart Posted April 13, 2011 Share Posted April 13, 2011 Hi there, I'm new to max and I'm working through the 3DATS beginner book and I'm trying to save a small sequence using the RAM Player but the book says to save it as a mov. file but there's no such option. I'm sure I'll need this in the future so any help would be much appreciated. Thank you : D Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted April 13, 2011 Share Posted April 13, 2011 In case you don't get an better answer for a while: Search the forum here. I'm pretty sure I recall there being an issue like "no quicktime in 64bit." At a guess, it won't matter if you use avi to work through the book. Link to comment Share on other sites More sharing options...
acjwalker Posted April 13, 2011 Share Posted April 13, 2011 had a similar issue in after effects, i had no quicktime installed., Do you? Link to comment Share on other sites More sharing options...
-MerlyN- Posted April 14, 2011 Share Posted April 14, 2011 Apple never made a 64bit quicktime, thats why you wont be able to save from max to mov in 64bit. If you cant live w/o it, you'll have to work in 32bit, where quicktime should be available. However I'd always suggest to save out imagesequences from max only and only combine them into a video file in post. That way you have full control over every frame while working on it. Link to comment Share on other sites More sharing options...
Fooch Posted April 14, 2011 Share Posted April 14, 2011 Aye .. always save to sequences.. if a crash happens mid process, at least you still have frames. Then export to mov via quicktime / aftereffects etc.. Apple never made a 64bit quicktime, thats why you wont be able to save from max to mov in 64bit. If you cant live w/o it, you'll have to work in 32bit, where quicktime should be available. However I'd always suggest to save out imagesequences from max only and only combine them into a video file in post. That way you have full control over every frame while working on it. Link to comment Share on other sites More sharing options...
R.Stewart Posted April 14, 2011 Author Share Posted April 14, 2011 Yeah Merlyn I did read today that doing it in post was the way to go. Thanks for consolidating that fact for me. Thank you everyone things are more clear now : D Link to comment Share on other sites More sharing options...
