sefianea Posted April 20, 2011 Share Posted April 20, 2011 Any suggestions on the best way to model these feathered edges.[ATTACH=CONFIG]42379[/ATTACH] Link to comment Share on other sites More sharing options...
BrianKitts Posted April 20, 2011 Share Posted April 20, 2011 couple options come to mind... 1. hair/fur modifier 2. scatter object 3. particle flow Link to comment Share on other sites More sharing options...
GUSN Posted April 20, 2011 Share Posted April 20, 2011 Hi guys, Jumping off the current subject, I didn't want to start a new thread. Question#1 What is the easiest way to make reveals on a wall without having to clean up any geometry or is it just better to add a tile map to the texture to get the same effect. Please see reference picture. [ATTACH=CONFIG]42383[/ATTACH]Please see Question#2 I I'm trying to create a terrain to apply a grass material. I converted to an editable poly but how can I subdivide an area to use the paint deformation tool to make it a bit uneven. I apologize with these questions but I'm self-teaching myself:) Thanks in advance. Link to comment Share on other sites More sharing options...
BrianKitts Posted April 20, 2011 Share Posted April 20, 2011 (edited) 1. mapping would be easiest, unless it's viewed up close in which case you'd clean up the surface an model. 2. subdivide the mesh, either the entire mesh with a subdivide or quadify modifier, or select specific faces and tesselate the mesh 3. always start a new thread don't hijack someone elses. (unless the current conversation has concluded and you have a VERY similar topic to add) Edited April 20, 2011 by BrianKitts Link to comment Share on other sites More sharing options...
GUSN Posted April 20, 2011 Share Posted April 20, 2011 1. mapping would be easiest, unless it's viewed up close in which case you'd clean up the surface an model. 2. subdivide the mesh, either the entire mesh with a subdivide or quadify modifier, or select specific faces and tesselate the mesh 3. always start a new thread don't hijack someone elses. (unless the current conversation has concluded and you have a VERY similar topic to add) Sorry!!!! I've started a new one. Link to comment Share on other sites More sharing options...
sefianea Posted April 21, 2011 Author Share Posted April 21, 2011 Thank you brian! I am self–taught as well. Link to comment Share on other sites More sharing options...
Jose Negrete Posted April 22, 2011 Share Posted April 22, 2011 sefianea, this might work http://maxplugins.de/max2011.php?search=&sort=Author its grass-o-matic Link to comment Share on other sites More sharing options...
