chow choppe Posted April 29, 2011 Share Posted April 29, 2011 hi all i am rendering an interior scene and i am stuck with some noise coming in the image. i have tried using very high settings but still the noise is coming. i ahev used 50 subdivisions in glossiness, noise threshold and adaptive amount .75 , .005 vray light subdivisons around 30 for the light that is visible in the image Can anyone tell the reason behind this. i am stuck here is the image Link to comment Share on other sites More sharing options...
Devin Johnston Posted April 29, 2011 Share Posted April 29, 2011 I can't see anything, post a bigger image. Link to comment Share on other sites More sharing options...
Chewbacca Posted April 29, 2011 Share Posted April 29, 2011 Have you tried unchecking "generate GI" for the glass object in the Vray properties? Not sure if that would be causing the promblem or not... Link to comment Share on other sites More sharing options...
FreakyDroid Posted April 29, 2011 Share Posted April 29, 2011 I agree with Maxer, the image is small. When I looked at it the first time I though it was a noise issue, but when I looked at it the second time, it seems like the problem is in the GI settings. If it is noise, then the only thing left to do is increase the max rate in your image sampler. If that doesn't fix it, post images from your render settings to try and solve the problem faster. Link to comment Share on other sites More sharing options...
