3darchitect Posted May 1, 2011 Share Posted May 1, 2011 Hey all, I'm doing some rendering work for a conceptual idea which involves a photo match and layering and such. Problem is, the image has a single vanishing point and an odd perspective and I can't get Sketchup to conform to the proper plane lines. I've attached the image in question. Any suggestions? Link to comment Share on other sites More sharing options...
Tommy L Posted May 1, 2011 Share Posted May 1, 2011 First rule of photo-montage; get a decent photo to work with. Dont know the answer to your query, but I do know you'll not get far using that photo, its horrible! Link to comment Share on other sites More sharing options...
3darchitect Posted May 1, 2011 Author Share Posted May 1, 2011 I'm aware of the bad quality of the image haha. That's just what I have to work with until the client gets me a better and wider shot. It's the same perspective though so its fine for what I need it for now. Obviously I won't be using that for the final photo match. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted May 2, 2011 Share Posted May 2, 2011 Well, if you are not using it for the final, I wouldn't waste a lot of time with it. But typically you just need to get the perspective close, and then do the last 5-10% of the perspective matching in Photoshop. Chances are you are not going to get it lined up perfectly. It is a common challenge in all 3d software, not just SketchUp. Link to comment Share on other sites More sharing options...
carlotristan3d Posted May 12, 2011 Share Posted May 12, 2011 You might have figured it out by now, but why don't you line up the grids with the column. Link to comment Share on other sites More sharing options...
