MulinoBianco Posted May 3, 2011 Share Posted May 3, 2011 hi guys i wanted to know how can I do something like this http://www.villeroy-boch.com/city/index.php?L=4&C=it&koje=7 I will use 3ds max v ray and photoshop,but I think that this is done by Flash or I am wrong.If someone can help me with some turoials or something i would me grateful. thanks Link to comment Share on other sites More sharing options...
rjg31 Posted May 3, 2011 Share Posted May 3, 2011 I use Easypano Tourweaver for my panoramas, http://www.easypano.com. Link to comment Share on other sites More sharing options...
MulinoBianco Posted May 3, 2011 Author Share Posted May 3, 2011 can you explain me a little bit how can i make some panorama? Link to comment Share on other sites More sharing options...
rjg31 Posted May 4, 2011 Share Posted May 4, 2011 Since you are using Vray, this is the process you would use to set up a panoramic render... 1st place your camera at eye level in the middle of the room that you want to render. 2nd, in the Vray render setup menu, go to the Vray Camera rollout and in the type selection box select spherical, then under that in the FOV box type in 360. 3rd thing to do will be to set up your resolution for the render, which has to be at a image aspect of 2.0, for example width 6000 x height 3000. Lastly, make sure your Vray settings are the way you want them, then render. Once you have the render completed, you can use a Easypano product like Panoweaver or Tourweaver to view your panorama. Hope this helps you! Link to comment Share on other sites More sharing options...
MulinoBianco Posted May 4, 2011 Author Share Posted May 4, 2011 thaks man,i'll try it... thanks a lot for a kind rispond Link to comment Share on other sites More sharing options...
sabbbin Posted May 27, 2011 Share Posted May 27, 2011 hello there, i'm using vray 1.5 in 3ds max 2010 and i dun have the spherical type option in the rollout. do i have to install some other version of max or is there something wrong with my settings. please help. Link to comment Share on other sites More sharing options...
rjg31 Posted June 2, 2011 Share Posted June 2, 2011 Here is a screen capture of what you should see to get you the right settings.... Link to comment Share on other sites More sharing options...
