clip 911 Posted May 4, 2011 Share Posted May 4, 2011 Studio/Institution: studentGenre: Residential ExteriorSoftware: 3ds max 2009 , photoshop cs4Description: my file got corrupted. i render this file in windows 7 64 bit. and archived it . Due to some reason i switched to xp 64 . now when i try to render it my system just hangs up. when i hide all my proxies then i can render the file. i know something is wrong with proxies but dunno what. plz help. (i have already done asset tracking and all textures and proxies are ok) moreover when i bring new proxies that i made in xp64 the render again stuck Link to comment Share on other sites More sharing options...
michaelidesm Posted May 4, 2011 Share Posted May 4, 2011 I would try this: while the file is open click :file-new-keep objects and save the new file. try to render it. I cant promise anything just an idea. Link to comment Share on other sites More sharing options...
clip 911 Posted May 5, 2011 Author Share Posted May 5, 2011 thanks for the suggestion bro , but did'nt worked out Link to comment Share on other sites More sharing options...
John Dollus Posted May 5, 2011 Share Posted May 5, 2011 if you use the mesh and instance them instead, does it still hang? depending on your ram, proxies may be hurting more than helping in this case. no idea why it would render in 7 but not xp64 though if the OS is the only thing that changed. are the proxies located on your local system or on a network drive? If not on your local system, I'd suggest trying that to remove any network or remote hardware issues. Link to comment Share on other sites More sharing options...
clip 911 Posted May 6, 2011 Author Share Posted May 6, 2011 yeah i did that too. if i try to make instance of any object its fine and rendering(proxies hide) . but the moment i bring any proxy into my scene the rendering just hangs, the time just keep go on increasing. and the proxies are on local system. Link to comment Share on other sites More sharing options...
John Dollus Posted May 9, 2011 Share Posted May 9, 2011 well, then, i wouldn't use proxies in this file. if you create a new file with only a camera and light and add in one of those same proxies or even create a new proxy, does it also hang? how about your system specs? Link to comment Share on other sites More sharing options...
