shikodesign2000 Posted May 8, 2011 Share Posted May 8, 2011 Hi my friends.. Long time since making volume light with vray renderer using direct light, I knew that I have to use shadow map type, and it worked before properly, but now, it doesn't work at all, can anybody help me?? Link to comment Share on other sites More sharing options...
shikodesign2000 Posted May 10, 2011 Author Share Posted May 10, 2011 I found that it works with normal camera not physical!! can anybody tell me why is that? cause I prefer using physical camera than normal.. Link to comment Share on other sites More sharing options...
notamondayfan Posted May 10, 2011 Share Posted May 10, 2011 Have you tried using physical camera, but turning off all the features like exposure, vignette, ect? Link to comment Share on other sites More sharing options...
albertomaciel Posted May 10, 2011 Share Posted May 10, 2011 notamondayfan, if these options are turned off there will be no advantage in using of vrayphysicalcam! oO shikodesign2000, i heard that is possible do what u want with the VrayEnvironmentFog (on environment and effects tab), but unfortunatelly i can't say how exactly. plz, if u find how to do, share! Link to comment Share on other sites More sharing options...
erickdt Posted May 10, 2011 Share Posted May 10, 2011 I don't know if you're using a newer version of VRay than 1.5 but volume light works fine for me regardless of what kind of camera I'm using. It will not however show up in a non-camera view... E Link to comment Share on other sites More sharing options...
shikodesign2000 Posted May 11, 2011 Author Share Posted May 11, 2011 It's working now with physical camera, but it gives black fog!! I tried in direct light and physical camera settings but no results.Only changing the direct light color changes the fog color, can anybody help me please.. Link to comment Share on other sites More sharing options...
sanmb Posted May 12, 2011 Share Posted May 12, 2011 Can u post v-ray settings? you might need to change Link to comment Share on other sites More sharing options...
