Noise Posted May 15, 2011 Share Posted May 15, 2011 I use Log Me In to access the office computers from home but the refresh for 3ds Max is almost nonexistent which makes it very difficult to use Max. Does anyone else use this and have you been able to overcome this problem ? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted May 15, 2011 Share Posted May 15, 2011 You can not model remotely. It is just not going to happen. The best you can do is open a file, and hit render. You can make a few changes to the model and parameters, but not a lot. Mostly you can just send and check renderings remotely. Alternately, ..if you are on a work machine at home, you can check out a 3dsMax license, and use that on the computer/laptop or, you could see if your company is willing to go through the process of giving you a home license. I don't know the details, but I believe all of Autodesk's products allow you to install a second copy on a home computer. This may also deal with borrowing a license, but I am not 100% sure. Link to comment Share on other sites More sharing options...
Noise Posted May 15, 2011 Author Share Posted May 15, 2011 Its not to model remotely - its more basic than that for example, I can't see the list of geometry in the Select by Scene dialog - it just doesn't show the list of items. All I want to do is view the dialog boxes and see what I would normally see when max is open. Strangely there isn't the same problem with other software. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted May 15, 2011 Share Posted May 15, 2011 Usually I can see the dialog boxes ok, but often have trouble with actual geometry when using Remote Desktop and a Cisco VPN. To get around this I switch the geometry to OpenGL instead DirectX. I doubt this will help with dialog boxes though. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted May 15, 2011 Share Posted May 15, 2011 You can try changing the graphics mode to Software. That could help, I guess... Link to comment Share on other sites More sharing options...
armilla Posted May 16, 2011 Share Posted May 16, 2011 I've not tried Log Me In, but with Go To My PC I was able to model in 3ds Max remotely and use all the functions, just as long as it wasn't a really heavy scene. I think Go To My PC have a 30 day demo you can try. Link to comment Share on other sites More sharing options...
Simon Moir Posted May 16, 2011 Share Posted May 16, 2011 Can you use a home license? Link to comment Share on other sites More sharing options...
Sketchrender Posted May 16, 2011 Share Posted May 16, 2011 I hope they have changed the way it used to be, which was export a file every evening to bring home and enter it at home to get it to work. A real pain when your trying to get out of the office or you don't want to go back into the office. phil Link to comment Share on other sites More sharing options...
armilla Posted May 18, 2011 Share Posted May 18, 2011 The 3ds max licence will allow you to have it installed on 2 computers, so you can have it at home and in the office, without all the export/import licence file hassle. Link to comment Share on other sites More sharing options...
Sketchrender Posted May 18, 2011 Share Posted May 18, 2011 Out of interest. What is the best for working remotly ? I used to use VNC . Windows 7 prof Link to comment Share on other sites More sharing options...
