ctk111 Posted May 25, 2011 Share Posted May 25, 2011 I have a number of objects that I have arrayed, but I want them to have a slight random shift so they're not perfectly aligned. This seams simple enough so I feel like I'm overlooking something. Any suggestions? Attached is an image of what I have so far. Link to comment Share on other sites More sharing options...
Fran Posted May 25, 2011 Share Posted May 25, 2011 Hi Chad, Have you tried Object Painter (Max 2011-2012)? You can use its Fill tool to array an object on selected edges of an editable poly. Here is an introduction on the Autodesk Youtube Channel: Link to comment Share on other sites More sharing options...
Tommy L Posted May 25, 2011 Share Posted May 25, 2011 This is a perfect application for 'Random Transform' (?) tool which is part of the Soulburn Scripts. You just pick your objects then key in your max/min values to shift and/or rotate in x/y/z (individually or in combo). Done! Link to comment Share on other sites More sharing options...
ctk111 Posted May 25, 2011 Author Share Posted May 25, 2011 Great, thanks for the suggestions. I'll give them both a try. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted May 25, 2011 Share Posted May 25, 2011 Tom stole my answer. Can't over-recommend Soulburn. Link to comment Share on other sites More sharing options...
notamondayfan Posted May 26, 2011 Share Posted May 26, 2011 http://www.scriptspot.com/3ds-max/scripts/mass-randomizer this is probably the easiest, fastest and just best! I also like using it because Undo actually works, unlike a lot of other random scripts!! Link to comment Share on other sites More sharing options...
