dande Posted May 26, 2011 Share Posted May 26, 2011 I have rendered out an animation. I would like to slow it down a little. The ideal answer is to go back into Max add more frames and re-render. I'm just wondering has anybody tried any other solutions. I tried remapped the speed in Premiere Pro but when I exported it out I found it a little jumpy. Link to comment Share on other sites More sharing options...
ihabkal Posted May 26, 2011 Share Posted May 26, 2011 I did it by making the animation play at lower frame speed, I once made it play at 15 frames per second, wasn't smooth but didn't jitter or jump. you can gain some speed from 30 to 24 frames at no loss of smoothness. Link to comment Share on other sites More sharing options...
erickdt Posted May 26, 2011 Share Posted May 26, 2011 You can use frame blending in AfterFX to smooth out jumpiness caused by slowing down footage. E Link to comment Share on other sites More sharing options...
dande Posted May 26, 2011 Author Share Posted May 26, 2011 Thanks. I'll have a play with it in After Effects Link to comment Share on other sites More sharing options...
alias_marks Posted May 27, 2011 Share Posted May 27, 2011 In after effects there's a couple native ways to do frame interpolation. Out of the bunch I've found pixel motion to work best. I've also seen a good example of twixtor doing a good job, if you have the budget - http://www.revisionfx.com/products/twixtor/ Link to comment Share on other sites More sharing options...
