Jonathanb Posted May 27, 2011 Share Posted May 27, 2011 Hello everyone, I'm a beginner and wanted to make a simple infinite background. In C4D it was easy, but 3ds max is a bit different. I'm using the new Autodesk 3Ds Max 2012 x64. I already tried this simple howto which didn't work for me. When i do this the plane becomes black like the background. But what he is doing is what I want to make in the 2012 version. Here is my project file: [ATTACH]42995[/ATTACH] Can someone help a beginner with this? Link to comment Share on other sites More sharing options...
Devin Johnston Posted May 27, 2011 Share Posted May 27, 2011 Post a image of the problem your having. Link to comment Share on other sites More sharing options...
Jonathanb Posted May 28, 2011 Author Share Posted May 28, 2011 Underneath are the two pictures that I have. The left one has a infinite white background and plane although this is a illusion. They used the material Matte/Shadow to accomplish this. In the right picture you have my comp. As you can see I have a big white plane, text, normal light and a sky light. I used the same Matte/Shadow material on the plane but it didn't work like in the video that I posted in my first post. How can I achieve the same result as in the first picture with Autodesk 3ds Max 2012? [ATTACH=CONFIG]43018[/ATTACH][ATTACH=CONFIG]43019[/ATTACH] --- Jonathan Link to comment Share on other sites More sharing options...
sanmb Posted May 30, 2011 Share Posted May 30, 2011 Hi john, To get infinite plane,I guess you are using plane in standard primitives please check size of the plane and increase as much you want to get infinite effect. The other method is just use v-ray plane. Link to comment Share on other sites More sharing options...
Jonathanb Posted May 30, 2011 Author Share Posted May 30, 2011 Hey Sanmb, Thank you for your reply. I can't make a plane that is that large, because my render time would be large too. I haven't seen a v-ray plane unless you mean that I need to use v-ray materials on the plane. Where can I find this v-ray plane in 3ds Max 2012? --- John Link to comment Share on other sites More sharing options...
sanmb Posted May 30, 2011 Share Posted May 30, 2011 Click on standard premitives slot,roll on to v-ray and u will find v-ray plane. Link to comment Share on other sites More sharing options...
Jonathanb Posted May 30, 2011 Author Share Posted May 30, 2011 Thank you Sanmb! Where in the properties of the plan can I find the switch to make it infinte? --- John Link to comment Share on other sites More sharing options...
sanmb Posted May 30, 2011 Share Posted May 30, 2011 John it is infinite. Link to comment Share on other sites More sharing options...
Jonathanb Posted May 30, 2011 Author Share Posted May 30, 2011 Thank you Sanmb! I'm going to try this as soon as possible. I'm curious about if it would work. Thanks again for your help Sanmb! --- John Link to comment Share on other sites More sharing options...
