tecton3d Posted June 1, 2011 Share Posted June 1, 2011 this is a noob question, but I can't find where my main toolbar (traditionally to the right) went. Is there a way to turn it back on? what the heck?! thanks Link to comment Share on other sites More sharing options...
nelpiper Posted June 2, 2011 Share Posted June 2, 2011 I´m assuming you mean the Command Panel? If so, this is very annoying and it happens quite often. Right click on a empty area of your TOOLBAR and check out whether the command panel is checked. If not, click on it. If it´s already checked and still of screen, uncheck it and then ckeck it again so you can put the focus on it. Right after this, press ALT+SPACE BAR and select MOVE from the drop down. Now use the arrow keys to bring back the panel. Hoe it helps. Good luck. Link to comment Share on other sites More sharing options...
