Sketchrender Posted June 2, 2011 Share Posted June 2, 2011 Hi May be a very simple answer to this. I have wipped my machine and installed Windows 7. I am slowly installing all the programmes i use. I have installed the new Autodesk Building Design Suite prem 2012. I am trying to install the hot fix for 2012, and by double clicking it it says it can not Installed by windows installer ? any idea what the story with that on. Thank you Phil Link to comment Share on other sites More sharing options...
luthias42 Posted June 2, 2011 Share Posted June 2, 2011 the one option I can think of is that you might need to run the installer as the admin. right click and towards the top of the menu you should see "run as admin". Hope this helps Link to comment Share on other sites More sharing options...
Sketchrender Posted June 2, 2011 Author Share Posted June 2, 2011 I am the administrator, so I don't get the run as. Strange can't get it to install. Thank you all the same. phil Link to comment Share on other sites More sharing options...
Gary Ledgerwood Posted June 2, 2011 Share Posted June 2, 2011 I had the same issue and found that there are separate installers for 3ds Max and 3ds Max design. Make sure you got the right one. Link to comment Share on other sites More sharing options...
