CHE Posted June 2, 2011 Share Posted June 2, 2011 (edited) Rendering and photomontage done for Bridgestone Firestone. Modo501, CADBuddy, Onyx Trees, Dosch3D, and Photoshop. 3D Rendering Photomontage Edited June 2, 2011 by CHE Link to comment Share on other sites More sharing options...
CHE Posted June 2, 2011 Author Share Posted June 2, 2011 Here is a screen grab of the scene: Link to comment Share on other sites More sharing options...
CHE Posted June 3, 2011 Author Share Posted June 3, 2011 Here is my Onyx to Modo work flow. Onyx is very flexible when it comes to poly count. You can customize your tree to suit your needs; from high poly for close-ups to low poly for long shots. I only export the trunk, bough, and branches from Onyx. Also, the Onyx LWO exporter has an option to "minimize" the poly count: Then, I use Photoshop to create textures from reference photos of the tree: Finally, I use a fur material for the leaves in Modo. The projection type in the texture locator needs to be set to implicit UV for the leaf maps: -Ernesto Link to comment Share on other sites More sharing options...
chorkee Posted November 18, 2011 Share Posted November 18, 2011 Thank you very much, if I found this thread I won't need to ask for onyx workflow on the other thread. Link to comment Share on other sites More sharing options...
CHE Posted November 18, 2011 Author Share Posted November 18, 2011 I'm glad to know that you have found the workflow useful. Let me know if you have any questions. -E Link to comment Share on other sites More sharing options...
chorkee Posted November 18, 2011 Share Posted November 18, 2011 I have a question about apply fur Material on small branches, how can I get tree texture on the small brunch. Because when I map leaf texture for my fur material it will appear on small branches also. Link to comment Share on other sites More sharing options...
CHE Posted November 18, 2011 Author Share Posted November 18, 2011 When you import the LWO file into Modo, the file is translated with polygons assigned to their corresponding tree parts. In the shader tree, you should be able to see materials per every tree part. Use these materials to make selections using the material selection tool. Then reassign the polygons to the material that you want to use for that specific tree part. So if you want to have a branch without leaves then assign that branch to the "trunk" or "bark" material in your shader tree. I hope it helps. -E Link to comment Share on other sites More sharing options...
chorkee Posted November 19, 2011 Share Posted November 19, 2011 [ATTACH=CONFIG]45818[/ATTACH] Thank you very much for your help. Now I can create my tree with a short period of time. Link to comment Share on other sites More sharing options...
CHE Posted November 21, 2011 Author Share Posted November 21, 2011 Great! I'm glad to help. -E Link to comment Share on other sites More sharing options...
