Alucobond Posted June 8, 2011 Share Posted June 8, 2011 I have imported acad 2010 aec walls into max2009. I believe they were imported and derived by layers, blocks, split by material. NO matter what i do I can't separate the walls to apply different materials to them. I've changed layers, Broken links of parents, etc. When I apply a material to one wall they all get that material. how do I make each wall unique so I can apply different materials to them?? Thanks, Kevin Link to comment Share on other sites More sharing options...
BrianKitts Posted June 8, 2011 Share Posted June 8, 2011 apply an edit mesh modifier and either detach the faces for unique materials, or apply material ID's within the editable mesh and use a multi-sub object material. Link to comment Share on other sites More sharing options...
Alucobond Posted June 8, 2011 Author Share Posted June 8, 2011 Brian, like a charm. thanks. what is the best way to import these objects if I have not set up materials before hand? Link to comment Share on other sites More sharing options...
