orenvfx Posted June 8, 2011 Share Posted June 8, 2011 hi My question is why whan im working on 3d max 2012 with "realistic mode" off i get high temperature and with the same scene on 3d max 2011 im working in low temp cpu. also in maya and cinema4d both of maya & c4d keep cpu cool even with high poly scene. in simple room scene in max 2012 whan im working on wireframe mode its get 50c cpu hot and with similar scene in maya, 3d max 2011 or c4d its about 30c cpu all of tham work smooth. i want to keep my cpu cooler as possible and with max 2012 its cant be done. so bad my system is i7 870 cpu cooler arctic freezer gtx 640 2gb 4 gb Link to comment Share on other sites More sharing options...
AJLynn Posted June 8, 2011 Share Posted June 8, 2011 What's the CPU utilization look like? Link to comment Share on other sites More sharing options...
orenvfx Posted June 9, 2011 Author Share Posted June 9, 2011 in 3d max 2012 i think when im rotate or drag the scene 3d max use 15 - 16 % cpu when im not doing nothing is 0 % cpu the same in 3d max 2011 but with low cpu temp Link to comment Share on other sites More sharing options...
AJLynn Posted June 9, 2011 Share Posted June 9, 2011 Do you have both installed? Can you go back and forth and observe the temp change? Link to comment Share on other sites More sharing options...
