northern monkey Posted June 13, 2011 Share Posted June 13, 2011 (edited) Hi there I have a major headache at the moment. I have a major contract on the go at the moment and have been requested to do a lighting analysis for a supermarket. We modelled and set the scene up, created the lighting rig including ies files and populated the shelves using proxied elements. In total the scene was 3 million polys and 800 lights. Now i have never done a scene like this before and anticipated the scene would take a while to render due to the number of lights but.......... i'm stripping out a 3000x1500 image in 10 300x1500 strips, so far 6 strips have taken 74hrs to drop on an i7 8gig machine. Is this expected?!! Or am I missing something? I've attached screen shots of my render settings (not at all high & fg map pre calculated)... any suggestions would be more than welcome! Thanks in advance Chris [ATTACH=CONFIG]43302[/ATTACH][ATTACH=CONFIG]43303[/ATTACH][ATTACH=CONFIG]43304[/ATTACH] Edited June 13, 2011 by northern monkey Link to comment Share on other sites More sharing options...
Justin Hunt Posted June 13, 2011 Share Posted June 13, 2011 It is highly recommended to set far attenuation on the lights which will allow you to lower the shadow samples as well. Do you really need all 800 lights? jhv Link to comment Share on other sites More sharing options...
northern monkey Posted June 14, 2011 Author Share Posted June 14, 2011 Cheers for that, will have a look at the attenuation, will also see if i can get rid of a few lights, but will only be able to loose 100 at a guess, as they're florescent light strips that span in strings across the store. If I halve the number of lights and double the intensity of the remainder will that create the same effect? Am used external visuals with one big light!!! Thanks for your help Link to comment Share on other sites More sharing options...
SgWRX Posted June 14, 2011 Share Posted June 14, 2011 i think halving the lights and increasing intensity might work. for me, instead of modeling 1 fixture with 4 light bulbs in it, i'll only put 1 light bulb and increase the intensity for say a 2ftx4ft fixture. Link to comment Share on other sites More sharing options...
northern monkey Posted June 15, 2011 Author Share Posted June 15, 2011 Cheers for all your input. I've stripped out half the lights, so I've got 1 light across two fixtures, added far attenuation, and increased the intensity of the remaining lights and......... the render is dropping at a couple of hours per strip! Which is a result, so thanks again and will know for next time! Link to comment Share on other sites More sharing options...
