aristocratic3d Posted June 15, 2011 Share Posted June 15, 2011 Hello guys, It has been long time since I have posted here. This problem might be silly but a complex for me. when I do batch renders from different camera with different file name like "bumper_design". But it out with the file name of bumper_design0000. and for the second camera (second frame of the batch render) output with the file name of "door_design0001". what I need is "bumper_design" for first frame and door_design for second frame. so that after making the batch render I have all my files in the proper name. Hope I was clear. Thanks in advance. Baki Link to comment Share on other sites More sharing options...
BrianKitts Posted June 15, 2011 Share Posted June 15, 2011 if you're using the batch renderer why are you relying on frame changes to switch cameras.... batch render should control the output names. I'm not sure I fully understand what you're trying to setup. multiple cameras all in one scene can easily be setup with unique outputs in the batch renderer. Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 16, 2011 Author Share Posted June 16, 2011 Thanks for your reply. I know that it produce indivisual file name. that did it for me too. But you know what happen? I get "0000"/"0001" after every file name based upon the frame number. I am trying to avoid that numeric part of the file name? Please let me know if everything is not clear. Thanks a million again. Baki Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 19, 2011 Author Share Posted June 19, 2011 Guys please do me a favor if anybody know how to solve this issue. I am in a critical situation. Link to comment Share on other sites More sharing options...
aristocratic3d Posted June 26, 2011 Author Share Posted June 26, 2011 No one seems to be able to solve this problem. or I need wait few more days. I remember I spent a day to solve a problem of a forum member. anybody can spend a few min to solve this issue? thanks in advance Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 26, 2011 Share Posted June 26, 2011 You still haven't explained what you are doing, but it sounds like you are rendering through Backburner, and that is what Backburner does. If you are linking your images, then change that, or use a file rename utility to remove the 4 digits from the end. Link to comment Share on other sites More sharing options...
aristocratic3d Posted July 2, 2011 Author Share Posted July 2, 2011 The problem is solved guys! I had to keep override preset unchecked. and check the render hidden geometry option. Some time its difficult to get the scene condition based upon comments. Thanks guys for your efforts. if you're using the batch renderer why are you relying on frame changes to switch cameras.... batch render should control the output names. I'm not sure I fully understand what you're trying to setup. multiple cameras all in one scene can easily be setup with unique outputs in the batch renderer. Link to comment Share on other sites More sharing options...
