efilana Posted June 15, 2011 Share Posted June 15, 2011 Hello Crowd! I ahve been having troubles with shadow channel. It is just empty. It shouldn't be a brainer, right? I looked everywhere to troubleshoot, but to no avail. Maybe somebody had similar experience? I use Rhino+Maxwell. Link to comment Share on other sites More sharing options...
Brodie Geers Posted June 15, 2011 Share Posted June 15, 2011 Maxwell's shadow channel works very differently from most. Basically, by default everything casts a shadow but nothing will receive shadows (so it will show up as a white image). You have to go into the material properties and check the Shadow box (not sure where that is in Rhino, but it'll be in the material properties somewhere). For example, I often do this for my grass material which I will later replace in post. My shadow channel will be completely white except for where the shadows fall on my grass so I can plug it in on a multiply layer. What it isn't for is some sort of ambient occlusion channel. -Brodie Link to comment Share on other sites More sharing options...
efilana Posted June 15, 2011 Author Share Posted June 15, 2011 Brodie, thank you very much - it worked. I found the shadow check box in material editor window. Thank you! Link to comment Share on other sites More sharing options...
cacomaurer Posted September 1, 2011 Share Posted September 1, 2011 i turned on the shadow channel and all the materials in the scene have the shadow marck cheked and i still have the same problem. thank you Link to comment Share on other sites More sharing options...
Brodie Geers Posted September 1, 2011 Share Posted September 1, 2011 could you post some screenshots? Environmental settings, at least one material's settings, and the image generated as the shadow channel would be helpful -Brodie Link to comment Share on other sites More sharing options...
cacomaurer Posted September 5, 2011 Share Posted September 5, 2011 fixed it, i had the "use sun" option unmarked, thanks!!! Link to comment Share on other sites More sharing options...
