acjwalker Posted June 21, 2011 Share Posted June 21, 2011 So have just update max to 2012 and installed SP1. We have a render farm with 8 machines then 7 machines which are our workstations. Problem is keep getting this error http://yfrog.com/z/gy9wairbj I have also attached the image. Now if we render on our machine with out back burner we have no problem but as soon as we send it through backburner to exactly the same machine the error occurs. The folder it is rendering it to has complete access unlocked. When I watch it it opens the max file up and the render window appears (either a strip or whole thing) it just closes just before it actually starts the rendering. At the moment I have uninstalled 2012 Backburner and am using backburner 2008.1.1 and it is working fine with Max 2012. Can anyone help at all? Cheers [ATTACH=CONFIG]43408[/ATTACH] Link to comment Share on other sites More sharing options...
acjwalker Posted June 21, 2011 Author Share Posted June 21, 2011 Ok sorted it, set my permissions so no notfications came up in the Action Centre and after reinstalling backburner 2012 I make sure I run the servers as Administrator. Done Link to comment Share on other sites More sharing options...
Ambrozoom3d Posted September 29, 2011 Share Posted September 29, 2011 acjwalker said: Ok sorted it, set my permissions so no notfications came up in the Action Centre and after reinstalling backburner 2012 I make sure I run the servers as Administrator. Done Hi I have something like the same problem. I have disabled user account control, I am running everything as administrator. The scene rendered 200 frames, and from this point I get errors on all my servers . Could you give me some advice ? Thanks a lot. Link to comment Share on other sites More sharing options...
