.Mat file
mistrymah
Hello Everyone...
Im very much new to 3d world... I've a concern regarding using .mat file... How do I use it in my scene... I did try using Material Editor>>> Get Material>>>> Material Library>>>Open>>> select but nothing show up to choose....
Please Help...
Thanks and Regards,
Mahendra
Thank u for replying this...
I do see the file while selecting in Material library however, when I click, it does not show within Material Editor.. ALso, How do verify if that .Mat file has any material in it.
Thanks and Regards,
Mahendra
When you open the material library you should see the header at the top of the window change from 'Material/Map Browser' to 'Material/Map Browser - ***.mat' Any materials contained in the library are listed below. When you double-click on a material it will be loaded into the current slot in the material editor.
To add new materials to the library you can click on 'Put to Library' in the material editor. Then make sure to save the library again before closing.
