anndrenaline Posted June 25, 2011 Share Posted June 25, 2011 I'm using 3ds max 9 with vray 1.5. I don't know why everytime when i render at a certain angle or zoom into smaller objects like furniture it comes out all wrong and jagged as though its half rendered. I'm using vray sun and GI is on. I presume my render setting are ok since it renders well in another scene. Help~ [ATTACH=CONFIG]43478[/ATTACH] Link to comment Share on other sites More sharing options...
avvid Posted July 1, 2011 Share Posted July 1, 2011 Hi anndrenaline. Are your units set-up correctly? I'd imagine that if, as far as V-Ray is concerned, that furniture is 0.01mm across, it will have trouble rendering it properly. Or it could just be texture co-ordinates. Are the models properly UVW-mapped? If you're using procedural textures, you should be fine, but if not, then that could explain it. Another thing is: did you import the models from another program? It could be that there's a problem with your geometry. Link to comment Share on other sites More sharing options...
