Kirkos Posted June 25, 2011 Share Posted June 25, 2011 Hi to everyone! I am using Rhino 4 and V-Ray for rendering. I am trying to increase manually the size of the rendered image (more than 2048x1536 pixels) but VRay crashes down! For sizes 2048x1536 or lower Vray works fine. Is there any idea of how to increase (or if I can increase) the size of the rendered image more than 2048x1536 without having VRay crashed? Best regards, Kirkos Link to comment Share on other sites More sharing options...
notamondayfan Posted June 27, 2011 Share Posted June 27, 2011 If vray for Max reacts the same way as Rhino, then the limitation is down to either hardware (not enough RAM), or the operating system (64 bit rather than 32 bit). What's your system config? Link to comment Share on other sites More sharing options...
Kirkos Posted June 28, 2011 Author Share Posted June 28, 2011 Thanks for the reply I use XP-64bit. Finally, after 3 days testing I found that there was a conflict between DRSpawner (ASGVis Rendering slave) and my antivirus program. The conflict was responsible for thew v-ray crash.... Link to comment Share on other sites More sharing options...
