nitin_arch Posted June 28, 2011 Share Posted June 28, 2011 [ATTACH=CONFIG]43501[/ATTACH]Hi guys!!!! First of all thanks for making such wonderful forum... I'm nitin and i'm new to this vray rendering with sketchup.. I've tried this render attached below...i'm having this problem in every interior that some white spots always comes in my scene... i've tried so many settings already...have searched a lot on net still no help... for indirect illumination Primary - irradiance map and secondary light cache. already tried these things - checked the sub pixel mapping, disabled the refractive gi caustic. antianalising filter - lanczos and catmull both Please if someone can help me in this matter. Thanks!!! vray ver 1.48.89 sketchup 8 Link to comment Share on other sites More sharing options...
luthias42 Posted June 28, 2011 Share Posted June 28, 2011 I'm not that familiar with Sketch-up, but with Max you can usually fix it by unchecking the box for effect reflections and making sure that your lights are invisible. Link to comment Share on other sites More sharing options...
nitin_arch Posted June 28, 2011 Author Share Posted June 28, 2011 Thanks Luthias for the quick reply.... will check it..... Link to comment Share on other sites More sharing options...
nitin_arch Posted June 28, 2011 Author Share Posted June 28, 2011 i've done both the things but still no change... Link to comment Share on other sites More sharing options...
FreakyDroid Posted June 28, 2011 Share Posted June 28, 2011 Looks to me like you've enabled Caustics in the Indirect Illumination tab/rollout. Turn it off. Link to comment Share on other sites More sharing options...
nitin_arch Posted June 28, 2011 Author Share Posted June 28, 2011 @Dimitar....no caustics are disabled.... Link to comment Share on other sites More sharing options...
FreakyDroid Posted June 28, 2011 Share Posted June 28, 2011 I was gonna suggest that you disable Affect Reflections and Specular for all your lights, but I see William already said the same thing. Nothing comes to my mind what can cause this, perhaps if you post screenshots from your render settings we can help you. Link to comment Share on other sites More sharing options...
John Dollus Posted June 28, 2011 Share Posted June 28, 2011 what happens if you turn off reflections in the vray globals and/or use a med grey override material? that will help you narrow down the problem. if you still get the splotches with a diffuse override material, then it's your calc settings. Link to comment Share on other sites More sharing options...
M V Posted July 7, 2011 Share Posted July 7, 2011 What are your render settings? Also, what types of lights are you using. Could have something to do with your subdiv settings on your lights. Seems to me that you need to crank up your settings. Link to comment Share on other sites More sharing options...
RayOfLight Posted July 8, 2011 Share Posted July 8, 2011 what are your lightcache subdivs settings and scale? Also, in irr.map, check sample visibility (if it exists in vray for SU) If you want to, you can send me your file and I'll check it for you, there are loads of things possible.. Link to comment Share on other sites More sharing options...
kippu Posted July 9, 2011 Share Posted July 9, 2011 this is a material issue , could be the chrome or the vray light material inside the chrome lights Link to comment Share on other sites More sharing options...
