Athena Posted August 11, 2004 Share Posted August 11, 2004 Does anyone know how to do a hidden line render of a scene in VIZ??? There is a wire frame option in the render scene dialog box, but it gets very confusing if there are more than a few solids. Link to comment Share on other sites More sharing options...
Jason Matthews Posted August 11, 2004 Share Posted August 11, 2004 There is really no way to do it that I am aware of. I believe there is a plugin that will work. I could be wrong. Link to comment Share on other sites More sharing options...
Richard McCarthy Posted August 12, 2004 Share Posted August 12, 2004 I am not sure how VIZ 2005 work, if it's the same as MAX 6 with Mental Ray integration, you can use mental ray to do hidden line rendering. Just select Mental ray as renderer, and load up a preset Toon render in render preset pop up. Link to comment Share on other sites More sharing options...
Chad Warner Posted August 12, 2004 Share Posted August 12, 2004 Or you can use Illustrate! or Vecta3d. If you have Viz4, Vecta came on the second disk (that you probably didn't get, but you can ask your reseller about) -Chad Link to comment Share on other sites More sharing options...
Harjeet Singh Posted August 12, 2004 Share Posted August 12, 2004 GET ILLUSTRATE! for MAX If you have FinalRender , it is there. Link to comment Share on other sites More sharing options...
