COLNAGOBOY Posted June 29, 2011 Share Posted June 29, 2011 (edited) http://www.ronenbekerman.com/making-of-cutipol-house-3d-render-by-marcus-dallmann/ I was following this tutorial and wondering how to use Sweep Modifier to make the overflow of the swimming pool. I'd appreciate it if someone can help me understand how to use Sweep Modifier to model the grill (overflow). Thank you Edited June 29, 2011 by COLNAGOBOY Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted June 29, 2011 Share Posted June 29, 2011 Link not working... Link to comment Share on other sites More sharing options...
COLNAGOBOY Posted June 29, 2011 Author Share Posted June 29, 2011 (edited) Link not working... Sorry, for some reason a web link cannot be pasted correctly on this forum. The domain address was swapped with cgarchitect.com automatically. (Attached with the correct web link with a text file) I was following this tutorial and wondering how to use Sweep Modifier to make the overflow of the swimming pool. I'd appreciate it if someone can help me understand how to use Sweep Modifier to model the grill (overflow). Thank you Edited June 29, 2011 by COLNAGOBOY Link to comment Share on other sites More sharing options...
marius e Posted June 29, 2011 Share Posted June 29, 2011 (edited) Not sure what u need to know? The edges (top) of the poly mesh (the cut out area) was selected, right clicked and and select "create shape". The shape is then selected and a sweep modifier is added. The profile of the sweep you either draw yourself, or use the modiefier's own profile. Nothing special in his sweep, its just 2 shapes (rectangular) that are offset from each other and sweeped, with a poly in the middle for the "gridd" which looks like a map of some sort. Edited June 29, 2011 by marius e Link to comment Share on other sites More sharing options...
COLNAGOBOY Posted June 29, 2011 Author Share Posted June 29, 2011 Thank you marius e, Could you elaborate a little bit more on your last description? I understand how you create the channel by selecting a path & a profile, but I don't understand how 2 rectangular that are offset from each other and swept, to create the lid of the overflow part. Thanks in advance. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted June 29, 2011 Share Posted June 29, 2011 From what I can see there, he simply created a profile for the overflow (kind of arc, maybe?) and sweeped it. Then, he applied a map (black and white stripes) for the opacity and that's it. Nothing special, really. Link to comment Share on other sites More sharing options...
COLNAGOBOY Posted June 29, 2011 Author Share Posted June 29, 2011 Thank you Rick, I thought the lids of the overflow were actual geometries instead of mapped images. Thanks for clearing up. Link to comment Share on other sites More sharing options...
