How do I model this lamp
carlangas
thanks for the help, I messed with it some more but got nowhere... thanks for the advice Matt. Dimitar, thank you much! I would love to be able to use that model you made. Can you also just sort of briefly mention how you did it if you can?
I started with a cylinder, removed the top and bottom caps, and just manually moved the verticies from top and side view to try and match the reference image. I added a shell modifier to give it thickness and another edit poly to make the supporting edges for the turbosmooth modifier. Its a rough version and needs refinement though.
Its a Max 2011 file http://www.sendspace.com/file/kwr3x7
