Antan Posted July 1, 2011 Share Posted July 1, 2011 Studio/Institution: Anthony DurayClient: PrivateGenre: OtherSoftware: 3ds Max 2011 - VRay 2.0 - Photoshop CS5Website: http://www.anthonyduray.comDescription: I found this building in a book named "Mexican Design" and wanted to give it a try. i tried to find as much reference as i could, using Google Earth to approximatively find the right mesurement and using Street View to take a look around. All is done with poly modeling, grass is for now an autograss plane. Trees are XFrog modified and textured for VRay with 2sides Material. For the BG i used a pictures on a simple plane using VRayLight Material, because using a VRayLight Dome with HDRI was overriding my environement picture. There is still much to do but that's one of my first complete project based on a photo. Here are some modifications i did then: - Material on the "black cube" - Tinted glass - Pavement modified (still some things to do like adjsutement and adding details) - I modified the side of the building, like an underground garage (not visible here) - Cars... from Evermotion, as i had them and wanted to use them at least one Every Comment will be welcome as i'm a beginner. Thanks Link to comment Share on other sites More sharing options...
alejandroserranomonforte Posted July 3, 2011 Share Posted July 3, 2011 I live 2 minutes away from this building haha, its good overall but i dont like the background because here in Yucatan there are no mountains, also the foliage i thinks it doesnt look real Link to comment Share on other sites More sharing options...
cmrodrigo Posted July 3, 2011 Share Posted July 3, 2011 nice start i think you should work carefully on your background thanks good luck Link to comment Share on other sites More sharing options...
Antan Posted July 3, 2011 Author Share Posted July 3, 2011 (edited) Thanks a lot for your advice (both of you). I worked on the building but i'm not good enough to re-create the real background for now, i still have to learn that's a fact. I'll work more on the background so, not the real one as i explained before, but trying to make it more "correct". As well as the foliage... i'm a beginner in "Vegetation & grass", as i said i started with Xfrog tree, modified then, but i'll have to take a better look on it, maybe going to try GrowFX to have a better control over the creation. Btw, here is a "Sunset/Night" version of it, there i can clearly see the BG problem :/ Edited July 3, 2011 by Antan Link to comment Share on other sites More sharing options...
matagne Posted July 4, 2011 Share Posted July 4, 2011 Dear Anthony, It is a very good start. AS sayed in other post, the BG (in the day light image) need to be changed, take another BG image because the one you are using has a different exposure compared to your scene and the palm on the right, behind the building, looks too big. I would have a look to the glass material as well. Keep us updated. Link to comment Share on other sites More sharing options...
aristocratic3d Posted July 13, 2011 Share Posted July 13, 2011 I am adding... The evening sky does not look like the one you added as background. do not use exponential color mapping for evening scene. IMHO. hope that helps Link to comment Share on other sites More sharing options...
