mistrymah Posted July 1, 2011 Share Posted July 1, 2011 I know it's not at all upto mark but, please blast with advice for me... i want to learn this... thanks in advance Link to comment Share on other sites More sharing options...
r3nder Posted July 1, 2011 Share Posted July 1, 2011 good for your first! You need to practice practice and more practice! put some lights in, view through the window, focus your textures, loads of things you can be doing, study others images etc. good luck! Link to comment Share on other sites More sharing options...
braddewald Posted July 1, 2011 Share Posted July 1, 2011 If you're looking for critiques and criticism, the correct place to go in this forum is to the architectural visualization gallery. The "General Discussions" area isn't really meant to show off your work. Also, it's best to tell us a little bit about the software you are using to create the image, so we know what to help you with and how to identify your problem areas. Otherwise, we don't really know if the deficiencies are your fault or just a limitation of the software itself. Link to comment Share on other sites More sharing options...
mistrymah Posted July 2, 2011 Author Share Posted July 2, 2011 points Noted.. Im working hard on this..Braddewald sir I'm using max 2010 with 1.5 vray version.. i'll keep this in my mind about the post next time...Thanks r3nder and braddewald Link to comment Share on other sites More sharing options...
mistrymah Posted July 3, 2011 Author Share Posted July 3, 2011 i've updated new photo of the same above , please review and advice, thanks Link to comment Share on other sites More sharing options...
cmrodrigo Posted July 3, 2011 Share Posted July 3, 2011 yes ok my partner r3 is correct if you are using vray put put vray light facing the point inside or the interior scene in parameter rollut click the visible. regarding for the textures i recommend you go to this helpful sites www.evermotion.org you can download some materials there.. thanks and a nice start good luck partner. and also to www.vyonyx.com. Link to comment Share on other sites More sharing options...
mistrymah Posted July 4, 2011 Author Share Posted July 4, 2011 I'm so sorry but, i'm bit confused in here.. do u mean, I should change the Camera angle or, shall i pur some more light through window coming in...? Link to comment Share on other sites More sharing options...
cmrodrigo Posted July 4, 2011 Share Posted July 4, 2011 send me the max file and i will send to you my settings in vray Link to comment Share on other sites More sharing options...
mistrymah Posted July 5, 2011 Author Share Posted July 5, 2011 here u go sir... just to ask what did u use for lighting? Link to comment Share on other sites More sharing options...
mistrymah Posted July 7, 2011 Author Share Posted July 7, 2011 i tried to put night scene with the same image and got this... i did put Omni is the center with the intensity of 0.20 but it gave me full day light.. please advice me on this. .. FYI... this is in exact dimension of the living room Thanks and Regards, Mak Link to comment Share on other sites More sharing options...
mistrymah Posted July 10, 2011 Author Share Posted July 10, 2011 hello sir, don't wan to rush anything, i didn't receive any reply from anyone... what's going on? thanks and waiting Mak Link to comment Share on other sites More sharing options...
