ktate403 Posted July 2, 2011 Share Posted July 2, 2011 I made a file in 2012 Design and needed to open it in 2011. It didn't work. But, I have purchased max files that run on all versions. What did those companies do to make their max files independent? How can I open my 2011 Design max file in 2011? Kathryn Link to comment Share on other sites More sharing options...
lucpet Posted July 2, 2011 Share Posted July 2, 2011 (edited) In 2012 select save as and in the "Save as Type" dropdown you will see the options to save as 2010 and 2011 versions. The only reason the previous files seemed independent was because your max version was either the same as or greater than the file you were opening format. I hope this helps Edited July 2, 2011 by lucpet Link to comment Share on other sites More sharing options...
ktate403 Posted July 2, 2011 Author Share Posted July 2, 2011 OK, I'll try this. Thanks. Link to comment Share on other sites More sharing options...
