ktate403 Posted July 5, 2011 Share Posted July 5, 2011 How to select the select object tool and then change "the mode to Window"? Where do you change the mode and where is window? Kathryn Link to comment Share on other sites More sharing options...
JonRashid Posted July 5, 2011 Share Posted July 5, 2011 Not sure your question is clear. But Selection mode is 2nd and 3rd buttons to right of selct mode button. If you want to affect left/right crossing this option can be customised in scene selction part of preferences dialogue box. Just under half way down on LHS. Link to comment Share on other sites More sharing options...
ktate403 Posted July 5, 2011 Author Share Posted July 5, 2011 The tool is "Window/Crossing". So, is that the window mode button? Link to comment Share on other sites More sharing options...
JonRashid Posted July 5, 2011 Share Posted July 5, 2011 This allows you to select by either drawing a window around the objects the two options either select everything within the window or everything within and all that is touched by the window. Link to comment Share on other sites More sharing options...
ktate403 Posted July 5, 2011 Author Share Posted July 5, 2011 So, is Window/crossing rhe Window mode I need or is it some other button? Link to comment Share on other sites More sharing options...
JonRashid Posted July 5, 2011 Share Posted July 5, 2011 I do not know what you mean by window mode. If you tell me what you are trying to achieve maybe I can help further. Link to comment Share on other sites More sharing options...
ktate403 Posted July 5, 2011 Author Share Posted July 5, 2011 Trying to attach two halves together. The book I am using mentions "window mode" a lot and I didn't know what that was. There is a section of the book I couldn't work thru as it wanted me to "make windows". This doesn't mean to make a window as we haven't learned that yet. I don't know what it means. I've conntated one of the authors and he said to press 'm', but 'm' brings up the Material Editor. So, I am lost with this window tool or mode. Link to comment Share on other sites More sharing options...
JonRashid Posted July 5, 2011 Share Posted July 5, 2011 I am still not sure what this window mode will allow you to do. Why does it ask you to do this. I am not sure what it means by window mode. To select objects with a window you just draw rectangle with select tool to do this. The other window mode that I can think of is when you change max into a window which can be moved around the screen rather than working with max maximised. If it isn't either of those can you cut and paste a passage with the window mode in so I can read it in context. Link to comment Share on other sites More sharing options...
ktate403 Posted July 5, 2011 Author Share Posted July 5, 2011 I am lost with this. If I find anything out, Ill repost. The author isn't responding to questions aanymore. I've only asked one. Thanks for your time. I'll try the author again and get back, if there is anything. Kathryn Link to comment Share on other sites More sharing options...
ktate403 Posted July 5, 2011 Author Share Posted July 5, 2011 Hear back from the author. He is talking about the Window/Crossing button. I'll have to see. Thanks, Kathryn Link to comment Share on other sites More sharing options...
