john2000 Posted July 5, 2011 Share Posted July 5, 2011 Hello, I have a problem- As you can see in my images attached, I have lit my scene with vray lights. When I render, the glass looks totally reflect and I can't see through it. I have rebuilt my scene twice. When I start adding lights it is as if vray turns them off - really odd I think. Could someone give some idea as to what might be happening with my setup. I have checked my glass material and re-applied it several times. The material is only has a small amount of reflection on it. Thanks Link to comment Share on other sites More sharing options...
notamondayfan Posted July 5, 2011 Share Posted July 5, 2011 What happens if you hide the glass objects are render the image? Link to comment Share on other sites More sharing options...
john2000 Posted July 5, 2011 Author Share Posted July 5, 2011 I took the glass off and the lights glow through. The glass is part of a multi-sub material, I put all of my house materials into this single multi-sub. Does this type of material ever create problems with lots of materials embedded in it? Maybe I should start with a new vraymaterial and build the glass material again. What would you do? Thanks for getting back to me:D Link to comment Share on other sites More sharing options...
notamondayfan Posted July 5, 2011 Share Posted July 5, 2011 is the glass attached to the wall? if so, make the glass separate object from a box, not a plane, as glass need thickness. also, can you post your glass material settings? Link to comment Share on other sites More sharing options...
