redzuan3828 Posted July 7, 2011 Share Posted July 7, 2011 Studio/Institution: freelanceGenre: Commercial ExteriorSoftware: 3ds max, vrayDescription: Hope someone can give idea how to finish off this train using 3ds max. thanks redzuan ayub Link to comment Share on other sites More sharing options...
luthias42 Posted July 7, 2011 Share Posted July 7, 2011 Not sure if I understand what you need. If you need the areas around the paths to smooth out do a soft select of the surrounding verts. and then tap the relax option in your polygon. If your talking about texturing it I would use groundwiz, it gives you a really good texture and a high level of control over what the ground should look like. Link to comment Share on other sites More sharing options...
