cmuscata Posted July 8, 2011 Share Posted July 8, 2011 Hey guys, dunno if anyone else has encountered this problem. I am trying to double the length of a rendered scene in after effects via frame blending. The base render extends fine with no flicker or noticeable artifacts but when i try to superimpose exr layers they are not frame blending. As a test i then tried working with just the exr layer - timestretching it with frameblend on and sure enough it does not frame blend. I cannot understand why this is happening...any suggestions? I tried precomposing it but no luck. I could render out the passes as tifs and then it wouldn´t be a prob but I have several scenes and i do not want to export every pass of every scene as a seperate file, it would become too unmanageable. The only solution i have is to composite the whole thing at normal speed and export and then timestretch that with frame blending, but again this is quite a nuisance as if i have to change any pass i have to go through a 2-step procedure again every time. Am i missing somehting here? Please any help really appreciated, i´m on a sick deadline which is why i´m only rendering half the frame sin the first place hehe. thanks guys Link to comment Share on other sites More sharing options...
Fooch Posted July 13, 2011 Share Posted July 13, 2011 Try precomping it. Then frame blend the precomp. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 14, 2011 Share Posted July 14, 2011 If the PreComp doesn't work I occasionally have to render out the sequence, and then create a second file that is strictly to blend the composited frames. Link to comment Share on other sites More sharing options...
