V-Ray 2 & 3ds max 2012 - Max doesn't launch with spawner
JSS
I just installed 3ds max 2012 and V-ray 2 on 3 different pc's, and when I start my V-ray DR Spawner, absolutely nothing happens :( 3ds max should launch with a vrayspawner.max file
I also tried booting my pc's with v-ray spawner service, but Max doesn't launch.
With max 2011 I had no problems with V-ray Distribute rendering :(
If I start 3ds max 2012 on those pc's, there are no problems rendering scenes with V-ray. So it's this DR Spawner application :(
Normally it's the latest v-ray version. V-ray 2.0 SP1 I think.
And I don't have much experience with backburner. At the moment I've switched back to Max 2011 and I just have to start v-ray DR spawner on some render slave pc's and I get my additional render buckets when I start to render. I don't really use backburner.
So strange. I have 3ds max 2011 with VRay 2.0 installed, and when I start the DR Spawner, 3ds max launches minimized
But when I do the same with 3ds max 2012 and VRay 2.0 on other computers, DR Spawner doesn't do anything at all. Vray works perfectly though in max 2012, so it's not really a license issue I think.
I think I'll just work with max 2011 at the moment. Maybe in the nearby future it will solve itself.
3ds max 2012 is really nice though :( But the render times are just too high for 1 computer, I prefer to use my 4 other pc's at home for distributed rendering
Hi JSS.
This is normally caused by a lack of permissions to the "network" folder within 3ds Max's installation folder.
To resolve it, either run V-Ray Spawner as an administrator, or give "Users" "Modify" permissions on the above folder.
If you need a more detailed explanation, please let me know.
Good luck!
Hmm. My main account is Administrator on those pc's... So normally all programs are run as administrator I think.
And I installed 3ds max 2011 with V-ray 2.0 SP1 and vrayspawner2011 runs perfectly :/
But i'll give it a try :) Thanks
Hi JSS.
If you're on Windows XP, then it should work in that case. However, with Vista and above, if you have UAC enabled, it won't run as an administrator unless you specifically ask it to, even if you're logged-in as an admin.
Yeah, I noticed that, and I can't explain it. All I know is that what you're describing happens to me if I don't change permissions or run the spawner as an admin.
Anyway, I'm curious as to whether this will solve your problem or not, so please post back.
Thanks.
I'm not a fan of UAC, so I disabled that on those windows 7 machines... I'll do another fresh install of 3ds max 2012 tomorrow with vray 2 SP1 and I'll run it as administrator. I'll keep you posted! Thanks!
  • 2 weeks later...
Guys , i don`t have any other versions installed , only max 2012 and only Vray 2 .. that's it , and still nothing happen and the spawner not running , all admin . no restrictions , firewall disabled .
and sure i turned on the Backburner for the first time .
can anyone help here please ?
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
I HAD A SAME PROBLEM... AND GUYS RESOLVE THIS... VERY FUNY AND WORKS FINE
Ok I got it working, you have to rename vraydummy2012.max and vraydummy2012.xml in 3ds folder to vraydummy2011.max and vraydummy2011.xml. (in max root directory is this two files)
SEE THIS FORUMU, for other detail!
and dont forget YOU MUST HAVE A VRAY 2.00.03
good luck!
http://forum.cgpersia.com/f56/v-ray-2-00-03-2012-support-x86-x64-32033/index2.html#ixzz1bq0RNXPB
  • 2 months later...
