TSuess Posted July 12, 2011 Share Posted July 12, 2011 [ATTACH=CONFIG]43724[/ATTACH] I want to extrude (A) this profile along (B) this path and then conform the result to © this plane. The result should be a curb following grade. Any thoughts? Is there a good plug-in for this? Any thoughts or ideas would be greatly appreciated. Thanks, Tom Edit: It's the conform part that I'm having trouble with. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted July 12, 2011 Share Posted July 12, 2011 You will need to conform the spline first before you do the sweep, otherwise your extrusion will get flattened. Maybe one of the glue plugins would be more suitable than conform for this. Link to comment Share on other sites More sharing options...
TSuess Posted July 12, 2011 Author Share Posted July 12, 2011 I know that 3dsMax will not allow you to conform a spline. I'll try Glue. Link to comment Share on other sites More sharing options...
davistalexander Posted July 12, 2011 Share Posted July 12, 2011 (edited) but glue will.. or slice the surface, extract a spline and use sweep to generate your loft .... bob's your uncle.. d Edited July 12, 2011 by davistalexander Link to comment Share on other sites More sharing options...
TSuess Posted July 12, 2011 Author Share Posted July 12, 2011 I just googled "Bob's your uncle" I had no clue what you were talking about. I learned something new. Link to comment Share on other sites More sharing options...
Dave Buckley Posted July 12, 2011 Share Posted July 12, 2011 shapemerge rather than conform? Then simply extract the path from the grade to use as a sweep. Link to comment Share on other sites More sharing options...
davistalexander Posted July 12, 2011 Share Posted July 12, 2011 TSuess said: I learned something new. We are all here to learn something. Davis Link to comment Share on other sites More sharing options...
TSuess Posted July 12, 2011 Author Share Posted July 12, 2011 Dave Buckley, I used shapemerge then extracted the spline. The spline just flattened back out. Lost all info on the Z axis. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted July 12, 2011 Share Posted July 12, 2011 Try converting to editable poly first before extracting the spline. Link to comment Share on other sites More sharing options...
Dave Buckley Posted July 12, 2011 Share Posted July 12, 2011 Yeh I didn't explain very well, it definately works, I use it daily this explains it much better http://jasonaddy.blogspot.com/2010/06/using-shapemerge-for-site-modeling.html Link to comment Share on other sites More sharing options...
Dave Buckley Posted July 12, 2011 Share Posted July 12, 2011 don't know how you can model sites without it Link to comment Share on other sites More sharing options...
TSuess Posted July 12, 2011 Author Share Posted July 12, 2011 I'm still missing something! I create my shapemerge and the extract function re-flattens the spline. So I convert to an Editable Poly and the option to extract disappears. Obvioiusly the sweep modifier is not working because it only functions with shapes or splines. What is the critical step that I am missing? Link to comment Share on other sites More sharing options...
TSuess Posted July 12, 2011 Author Share Posted July 12, 2011 (edited) OK I got it. Use the "border" sub-object of your Editable Poly. Right click on it and choose "Create Shape" Ah-ha. Edit: [ATTACH=CONFIG]43729[/ATTACH] Edited July 12, 2011 by TSuess Link to comment Share on other sites More sharing options...
Dave Buckley Posted July 12, 2011 Share Posted July 12, 2011 yup, after shapemerge, convert the ground back into editable poly, go to edge sub-object mode, select the edges that have just been merged onto the ground, then create shape from selection that will give you a line that is detached from the ground but sits exactly on top of it where it should do Link to comment Share on other sites More sharing options...
