Problem applying material
TLAnh
Hi all,
I'm currently using 3ds max 2011 and while trying to apply some materials, i encountered a problems. I applied the same material to 3 objects but only one of them shows it when i render the scene.
I tried to google but didn't find anything that helps so any help would be appreciated.
Thanks in advance :D
Since the others are the right color that makes me think the texture is being applied only very very small. This happens often enough, texture coordinates aren't what you think they should be. A very common reason for me is the object and map have different values for "Real World Coordinates." One will be off and the other on.
