Matte from VrayWireColor?
I have a question about matting in AfterEffects.
I would like to generate a matte from a Vray WireColor pass. This pass is based on the wire color, and often ranges from purples , greens, oranges, yellows, etc.. I am not sure if there is a way to set a matte based on one of the individual colors.
It seems like there should be a way to sample a color, and then assign that sampled color to the alpha channel.
This is easy enough with an RGB multimatte, but can it be as easy with a wire color matte? I know it probably will not be as clean, but it would be a big time savings when you find out you need an unanticipated matte for a section of animation.
Edited by Crazy Homeless Guy
Wouldn't you know it, ...one of my MultiMattes was turned off today, but I did have a wire pass, so I needed to use that to create a matte to adjust a color on a chair. It is funny how you can anticipate a problem, and then it happens.
Solution:
If you set a 'Color Key' effect on your Wire Pass, you can then sample a color in the wire pass. This color will then act as the alpha channel.
Then create a adjustment layer just below the Wire Pass matte, and set the Track Matte to Inverted Alpha. Now you can make the necessary color adjustment based on the Wire Pass.
I love a conversation that's started and finished by one person, without any other interference, it's much neater this way..
I was just trying to do the exact same thing, and this works perfectly.
Apologies for crashing your conversation crazy homeless guy..
D
  • 3 weeks later...
;) .. precomp it .. and possibly add a simple choker / matte choker to deal with the nasty edges. Simple choker does a good job smoothing out edges quickly.
Anything can be keyed if you think of it as a greyscale image .. (for a luma key)
